Zum Hauptinhalt wechseln
Zotac GTX 1080 Ti Mini Fans Replacement
Was du brauchst
  1. Zotac GTX 1080 Ti Mini Fans Replacement, Zotac GTX 1080 Ti Mini Fans: Schritt 1, Bild 1 von 2 Zotac GTX 1080 Ti Mini Fans Replacement, Zotac GTX 1080 Ti Mini Fans: Schritt 1, Bild 2 von 2
    • Be sure to properly ground yourself with an anti-static wristband before working on the graphics card.
    • Use a Phillips #0 screwdriver to remove the two 4mm screws from the right side of the shroud.
  2. Zotac GTX 1080 Ti Mini Fans Replacement: Schritt 2, Bild 1 von 2 Zotac GTX 1080 Ti Mini Fans Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove the two 4mm screws from the left side of the shroud.
  3. Zotac GTX 1080 Ti Mini Fans Replacement: Schritt 3, Bild 1 von 2 Zotac GTX 1080 Ti Mini Fans Replacement: Schritt 3, Bild 2 von 2
    • Look for the fan header located beside the 16-pin power connector.
    • Gently pry the fan connector apart from the header with a flathead screwdriver.
  4. Zotac GTX 1080 Ti Mini Fans Replacement: Schritt 4, Bild 1 von 2 Zotac GTX 1080 Ti Mini Fans Replacement: Schritt 4, Bild 2 von 2
    • Slowly and carefully lift the shroud off the heatsink.
    • During this step, make sure not to damage the LED connector that is still connecting the shroud to the PCB.
    • Flip the shroud along the top of the graphics card.
  5. Zotac GTX 1080 Ti Mini Fans Replacement: Schritt 5, Bild 1 von 3 Zotac GTX 1080 Ti Mini Fans Replacement: Schritt 5, Bild 2 von 3 Zotac GTX 1080 Ti Mini Fans Replacement: Schritt 5, Bild 3 von 3
    • Remove the three 3 mm Phillips screws holding the fans to the heatsink with a Phillips #0 screwdriver.
    • Remove the broken fans.
  6. Zotac GTX 1080 Ti Mini Fans Replacement: Schritt 6, Bild 1 von 3 Zotac GTX 1080 Ti Mini Fans Replacement: Schritt 6, Bild 2 von 3 Zotac GTX 1080 Ti Mini Fans Replacement: Schritt 6, Bild 3 von 3
    • Place the replacement fan on top of the heatsink with the screw holes aligned.
    • Screw the fans into place using a Phillips #0 screwdriver.
  7. Zotac GTX 1080 Ti Mini Fans Replacement: Schritt 7, Bild 1 von 1
    • Reconnect the fan connector to its header.
  8. Zotac GTX 1080 Ti Mini Fans Replacement: Schritt 8, Bild 1 von 3 Zotac GTX 1080 Ti Mini Fans Replacement: Schritt 8, Bild 2 von 3 Zotac GTX 1080 Ti Mini Fans Replacement: Schritt 8, Bild 3 von 3
    • Place the shroud back over the heatsink and screw it back into place using a Phillips #0 screwdriver.
Abschluss
Hopefully, your graphics card is fully replaced and completely working now.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Victor Pan
175 Reputation
1 Anleitung geschrieben
York University, Team S16-G7, Turner Winter 2021 Mitglied von York University, Team S16-G7, Turner Winter 2021
YORK-TURNER-W21S16G7
3 Mitglieder
2 Anleitungen geschrieben
Ein Kommentar
Do you know what size (diameter and thread) the 4mm and 3mm screws are?
cchagadorn - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 59
Insgesamt: 4,701
