Einleitung
Dismantling guide
Was du brauchst
To remove the cover it is necessary to disconnect the DB9 connector
To remove the motherboard it is necessary to remove the 6 screws that fix it to the chassis
If the device does not save the time, you can replace the battery
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
100%
Hier starten ›
