Zum Hauptinhalt wechseln
anko Oscillating Fan Heater Disassembly
Was du brauchst
  1. anko Oscillating Fan Heater Disassembly, 分解: Schritt 1, Bild 1 von 1
    • Show what the package look like.
  2. anko Oscillating Fan Heater Disassembly: Schritt 2, Bild 1 von 2 anko Oscillating Fan Heater Disassembly: Schritt 2, Bild 2 von 2
    • Remove the seven screws on the top, four can be seen in the picture, and there are three similar screws on the opposite side.
    • Note: Disassembly requires the use of a special screwdriver, as shown in the picture.
  3. anko Oscillating Fan Heater Disassembly: Schritt 3, Bild 1 von 1
    • Remove the rubber cover, then loosen the two internal phillips screws to release the fan and heating wire.
  4. anko Oscillating Fan Heater Disassembly: Schritt 4, Bild 1 von 2 anko Oscillating Fan Heater Disassembly: Schritt 4, Bild 2 von 2
    • Pry open the two knobs (they are plugged in), you can see two screws on each side, unscrew them to remove the gear switch and temperature switch.
  5. anko Oscillating Fan Heater Disassembly: Schritt 5, Bild 1 von 2 anko Oscillating Fan Heater Disassembly: Schritt 5, Bild 2 von 2
    • Unscrew these two screws to separate the upper and lower parts.
    • Pallets require special tools to separate.
  6. anko Oscillating Fan Heater Disassembly: Schritt 6, Bild 1 von 2 anko Oscillating Fan Heater Disassembly: Schritt 6, Bild 2 von 2
    • As shown at the bottom, just unscrew all the phillips screws.
    • Note: All terminals can be pulled out only by pressing the part shown in Figure 2 with a small or a tool, and should not use brute force.
  7. anko Oscillating Fan Heater Disassembly: Schritt 7, Bild 1 von 1
    • The complete disassembly is shown
Abschluss
当重新组装你的设备时,请按照说明的相反顺序进行操作。
Tom YAN
217 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 19
Insgesamt: 205
