Zum Hauptinhalt wechseln
bObsweep Robotic Vacuum Battery Replacement
Was du brauchst
Einführungsvideo
  1. bObsweep Robotic Vacuum Battery Replacement, Battery: Schritt 1, Bild 1 von 3 bObsweep Robotic Vacuum Battery Replacement, Battery: Schritt 1, Bild 2 von 3 bObsweep Robotic Vacuum Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Unscrew the battery's cover plate on bObsweep's underside, above the main brush.
    • Lift the cover plate to expose the battery.
  2. bObsweep Robotic Vacuum Battery Replacement: Schritt 2, Bild 1 von 3 bObsweep Robotic Vacuum Battery Replacement: Schritt 2, Bild 2 von 3 bObsweep Robotic Vacuum Battery Replacement: Schritt 2, Bild 3 von 3
    • Lift the battery up and out of its compartment.
    • Using both hands, pinch the plastic connector where the battery's wiring attaches to bObsweep and pull apart to disconnect.
  3. bObsweep Robotic Vacuum Battery Replacement: Schritt 3, Bild 1 von 3 bObsweep Robotic Vacuum Battery Replacement: Schritt 3, Bild 2 von 3 bObsweep Robotic Vacuum Battery Replacement: Schritt 3, Bild 3 von 3
    • Connect the wires of the new battery. Push together tightly and it will lock in place.
    • Tuck the wires down inside the battery compartment on the right side.
    • Lower the battery down into bObsweep with the barcode facing up.
  4. bObsweep Robotic Vacuum Battery Replacement: Schritt 4, Bild 1 von 3 bObsweep Robotic Vacuum Battery Replacement: Schritt 4, Bild 2 von 3 bObsweep Robotic Vacuum Battery Replacement: Schritt 4, Bild 3 von 3
    • Lower the cover down so it lies flat and the screw holes of the cover line up with those on bObsweep.
    • Reinstall the two screws removed in step one to secure the cover and battery in place.
Abschluss
A quick fix for bObsweep's power supply. Changing an old lithium ion battery for a new one ensures the vacuum will work longer with fewer charging breaks.
Eine weitere Person hat diese Anleitung absolviert.
Tatiana
737 Reputation
17 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 2,810
