Einleitung
This guide shows how to replace the battery for the d.light Solar Lantern S2.
Was du brauchst
To remove the lens, three T15 x 12.5mm screws must be removed by a T15 head screwdriver.
The location of the other two screws are marked in red.
After the lens has been removed the back cover needs to be removed. There are no snaps or screws holding it in place.
Take the battery out of its setting. It is only held in by friction (no snaps or screws).
Disconnect the battery by unpluging the white connector.
Install the new battery
4 weitere Nutzer:innen haben diese Anleitung absolviert.
