Zum Hauptinhalt wechseln
dreamGEAR Quad Dock Pro Electrical Port Replacement
Was du brauchst
  1. dreamGEAR Quad Dock Pro Electrical Port Replacement, Prerequisite Guide to Accessing Interior: Schritt 1, Bild 1 von 2 dreamGEAR Quad Dock Pro Electrical Port Replacement, Prerequisite Guide to Accessing Interior: Schritt 1, Bild 2 von 2
    • Remove the rubber foot pads on the bottom of the device using a plastic opening tool.
  2. dreamGEAR Quad Dock Pro Electrical Port Replacement: Schritt 2, Bild 1 von 2 dreamGEAR Quad Dock Pro Electrical Port Replacement: Schritt 2, Bild 2 von 2
    • Remove the six 2 mm PH0 screws on the bottom of the device.
    • Four of those screws are located under the foot pads.
  3. dreamGEAR Quad Dock Pro Electrical Port Replacement: Schritt 3, Bild 1 von 1
    • Gently remove the bottom of the device.
  4. dreamGEAR Quad Dock Pro Electrical Port Replacement, Mother Board: Schritt 4, Bild 1 von 2 dreamGEAR Quad Dock Pro Electrical Port Replacement, Mother Board: Schritt 4, Bild 2 von 2
    • Remove the four 1.8 mm J1 screws.
    • Remove the two 2mm PH0 screws.
  5. dreamGEAR Quad Dock Pro Electrical Port Replacement: Schritt 5, Bild 1 von 1
    • Gently pick up the mother board
    • Pick the mother board straight up or you may risk damaging the mini-USB charging ports.
  6. dreamGEAR Quad Dock Pro Electrical Port Replacement: Schritt 6, Bild 1 von 2 dreamGEAR Quad Dock Pro Electrical Port Replacement: Schritt 6, Bild 2 von 2
    • Use a plastic opening tool or similar tool to gently pry the power ribbon cord out of its port.
  7. dreamGEAR Quad Dock Pro Electrical Port Replacement, Electrical Port: Schritt 7, Bild 1 von 3 dreamGEAR Quad Dock Pro Electrical Port Replacement, Electrical Port: Schritt 7, Bild 2 von 3 dreamGEAR Quad Dock Pro Electrical Port Replacement, Electrical Port: Schritt 7, Bild 3 von 3
    • Locate the three solder connections for the electrical port.
    • Desolder the connection points following the instructions included with your soldering kit as you remove the port.
    • FIRE HAZARD! BURN DANGER! Follow all the safety precautions included with your soldering kit.
    • It is helpful to use a nylon or metal spudger or tweezers for the removal of this component, pieces of which are very hot.
    • You can follow iFixit's guide to soldering here.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jacob
757 Reputation
6 Anleitungen geschrieben
Colorado Springs, Team 4-4, Panko Spring 2015 Mitglied von Colorado Springs, Team 4-4, Panko Spring 2015
UCCS-PANKO-S15S4G4
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 300
