Zum Hauptinhalt wechseln
dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement
Was du brauchst
  1. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Prerequisite Guide to Accessing Interior: Schritt 1, Bild 1 von 2 dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Prerequisite Guide to Accessing Interior: Schritt 1, Bild 2 von 2
    • Remove the rubber foot pads on the bottom of the device using a plastic opening tool.
  2. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: Schritt 2, Bild 1 von 2 dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: Schritt 2, Bild 2 von 2
    • Remove the six 2 mm PH0 screws on the bottom of the device.
    • Four of those screws are located under the foot pads.
  3. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: Schritt 3, Bild 1 von 1
    • Gently remove the bottom of the device.
  4. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Mother Board: Schritt 4, Bild 1 von 2 dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Mother Board: Schritt 4, Bild 2 von 2
    • Remove the four 1.8 mm J1 screws.
    • Remove the two 2mm PH0 screws.
  5. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: Schritt 5, Bild 1 von 1
    • Gently pick up the mother board
    • Pick the mother board straight up or you may risk damaging the mini-USB charging ports.
  6. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: Schritt 6, Bild 1 von 2 dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: Schritt 6, Bild 2 von 2
    • Use a plastic opening tool or similar tool to gently pry the power ribbon cord out of its port.
  7. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Power Board: Schritt 7, Bild 1 von 2 dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement, Power Board: Schritt 7, Bild 2 von 2
    • Remove the four 1.8 mm PH0 screws that are holding the board in.
    • When you remove these screws, the plastic cups inside the PS Move stations will fall out.
  8. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: Schritt 8, Bild 1 von 1
    • Pick up the board.
    • Pick the board straight up, or you risk damaging the charging ports.
  9. dreamGEAR Quad Dock Pro Power Ribbon Cord Replacement: Schritt 9, Bild 1 von 1
    • Using a plastic opening tool or a similar tool, gently pry the power ribbon cord out of its port.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jacob
757 Reputation
6 Anleitungen geschrieben
Colorado Springs, Team 4-4, Panko Spring 2015 Mitglied von Colorado Springs, Team 4-4, Panko Spring 2015
UCCS-PANKO-S15S4G4
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 196
