Zum Hauptinhalt wechseln
e-lite web150 Disassembly
Was du brauchst
  1. e-lite web150 Disassembly, removing the blower nozzle: Schritt 1, Bild 1 von 1
    • Firmly press the yellow button and slide the blower nozzle off.
    Frag FixBot
    Kommentar hinzufügen
  2. e-lite web150 Disassembly, un-screwing: Schritt 2, Bild 1 von 1
    • un-screw all of the screws
    Frag FixBot
  3. e-lite web150 Disassembly, opening: Schritt 3, Bild 1 von 1
    • pull apart the 2 halves
    Frag FixBot
  4. e-lite web150 Disassembly, The inside: Schritt 4, Bild 1 von 1
    • This is the inside of the blower
    Frag FixBot
  5. e-lite web150 Disassembly, pulling out the switch and plug: Schritt 5, Bild 1 von 2 e-lite web150 Disassembly, pulling out the switch and plug: Schritt 5, Bild 2 von 2
    • gently pull out the power plug and switch
    Frag FixBot
  6. e-lite web150 Disassembly, removing the motor: Schritt 6, Bild 1 von 2 e-lite web150 Disassembly, removing the motor: Schritt 6, Bild 2 von 2
    • gently pull out the motor paying attention to which side it came out of.
    Frag FixBot
  7. e-lite web150 Disassembly, putting the motor back in: Schritt 7, Bild 1 von 1
    • clean the dust out if you need to. then carefully put the motor back in making sure you put both of the tabs on the motor into their respective slots. you can't see the other one because I had to crop it out.
    Frag FixBot
  8. e-lite web150 Disassembly, putting the plugs back in their places: Schritt 8, Bild 1 von 1
    • carefully put the plugs back into their holders.
    Frag FixBot
  9. e-lite web150 Disassembly, closing it up: Schritt 9, Bild 1 von 1
    • fit the 2 halves back together
    Frag FixBot
  10. e-lite web150 Disassembly, screwing in the screws: Schritt 10, Bild 1 von 1
    • replace all of the screws
    Frag FixBot
  11. e-lite web150 Disassembly, re-attaching the blower nozzle: Schritt 11, Bild 1 von 1
    • slide the blower nozzle on to the main body until it locks in place, you are done.
    Frag FixBot
Ziellinie
Eine weitere Person hat diese Anleitung absolviert.
Alex Pollard
119 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 31
Insgesamt: 696
