Einleitung
Steps to follow if you'd like to replace or upgrade the optical drive in your eMac.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. It should be noted that these guides are written based on a late-model eMac (2005, 1.42GHz, DDR). They will differ slightly from the older model eMacs that use PC-133 RAM. Lay the eMac screen-down on a flat surface. I've found it convenient to use a carpeted floor because the computer is so heavy. Remove the single phillips #2 screw on the RAM door, and remove the door
    • It should be noted that these guides are written based on a late-model eMac (2005, 1.42GHz, DDR). They will differ slightly from the older model eMacs that use PC-133 RAM.
    • Lay the eMac screen-down on a flat surface. I've found it convenient to use a carpeted floor because the computer is so heavy.
    • Remove the single phillips #2 screw on the RAM door, and remove the door
    • The screw is captive in the door, so don't worry about losing it.
  2. Before starting this process it's important to note that the eMac can have some seriously dangerous voltages inside of it, thanks to the CRT display. Before working on an eMac, you should unplug it, press the power button to clear any stored charge on the motherboard, and then let it sit for 24-hours (or more) to allow the CRT to discharge.
    • Before starting this process it's important to note that the eMac can have some seriously dangerous voltages inside of it, thanks to the CRT display. Before working on an eMac, you should unplug it, press the power button to clear any stored charge on the motherboard, and then let it sit for 24-hours (or more) to allow the CRT to discharge.
    • You can read more about CRT safety procedures here. If you aren't experienced with working on devices featuring a CRT, it's recommended that you don't proceed any further.
    • On the bottom side of the eMac, remove the following screws:
    • A single 2.5mm hex screw
    • Two #2 phillips screws
  3. Remove two 2.5mm hex screws from each of the other sides of the computer. Remove two 2.5mm hex screws from each of the other sides of the computer. Remove two 2.5mm hex screws from each of the other sides of the computer.
    • Remove two 2.5mm hex screws from each of the other sides of the computer.
  4. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  5. Now, the shell can almost be separated from the computer. There is a cable that connects to the power button. This must be disconnected before removing the housing completely.
    • Now, the shell can almost be separated from the computer.
    • There is a cable that connects to the power button. This must be disconnected before removing the housing completely.
    • Lift the housing enough to allow you to fit your hand through the access door, and disconnect the cable at the power button.
  6. Now the entire shell can be removed from the computer.
    • Now the entire shell can be removed from the computer.
  7. The motherboard access panel is held on by 4 phillips #2 screws. Remove the screws, then use your fingers to pull on the top tabs to separate the panel from the computer frame. Remove the screws, then use your fingers to pull on the top tabs to separate the panel from the computer frame.
    • The motherboard access panel is held on by 4 phillips #2 screws.
    • Remove the screws, then use your fingers to pull on the top tabs to separate the panel from the computer frame.
  8. The eMac uses a standard 5.25" IDE optical drive. Most off-the-shelf drives should work as a replacement with minor modification. The jumper setting for the drive should be "CS". Start by disconnecting the IDE and power cables from the drive.
    • The eMac uses a standard 5.25" IDE optical drive. Most off-the-shelf drives should work as a replacement with minor modification. The jumper setting for the drive should be "CS".
    • Start by disconnecting the IDE and power cables from the drive.
  9. The drive is held in by two phillips #2 screws on each side. Remove these. The drive is held in by two phillips #2 screws on each side. Remove these.
    • The drive is held in by two phillips #2 screws on each side. Remove these.
  10. The drive should now come free. The drive should now come free.
    • The drive should now come free.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Chris Green
32.915 Reputation
45 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
285 Mitglieder
800 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 25
Insgesamt: 297
