Zum Hauptinhalt wechseln
enTourage Pocket eDGe Battery Replacement
Was du brauchst
  1. enTourage Pocket eDGe Battery Replacement, Battery: Schritt 1, Bild 1 von 3 enTourage Pocket eDGe Battery Replacement, Battery: Schritt 1, Bild 2 von 3 enTourage Pocket eDGe Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Make sure the device is powered off before beginning.
    • Open the Pocket Edge and place device with the screens face down. The side containing the stylus should be on the left.
    • Remove all eight elliptical rubber tabs covering screws using your finger or spudger.
  2. enTourage Pocket eDGe Battery Replacement: Schritt 2, Bild 1 von 1
    • Using your J1 Phillips head screwdriver, remove all eight 6mm screws from the back of your device.
  3. enTourage Pocket eDGe Battery Replacement: Schritt 3, Bild 1 von 3 enTourage Pocket eDGe Battery Replacement: Schritt 3, Bild 2 von 3 enTourage Pocket eDGe Battery Replacement: Schritt 3, Bild 3 von 3
    • Using the plastic opening tool, lift the back plate from both sides of your device and remove them.
  4. enTourage Pocket eDGe Battery Replacement: Schritt 4, Bild 1 von 1
    • Locate the side containing the battery. Lift the top of the battery out using your finger and the indentation at the top.
  5. enTourage Pocket eDGe Battery Replacement: Schritt 5, Bild 1 von 1
    • Carefully unplug the bottom side of the battery from the connecting plug and set the disconnected battery aside.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Adrian Do
355 Reputation
3 Anleitungen geschrieben
University of Alabama, Team 1-3, Sydow campbell Fall 2015 Mitglied von University of Alabama, Team 1-3, Sydow campbell Fall 2015
UA-SYDOW CAMPBELL-F15S1G3
4 Mitglieder
Ein Kommentar
Great tutorial! I have two of these. Does anyone know where I can buy a replacement battery? I have looked everywhere. I would retrofit if I could find one large and flat enough. 7.2v 2000mA. Hate to have to trash them but they don’t make parts anymore.
Ron - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 15
Insgesamt: 1,414
