Einleitung
If your eufy Robovac 11 isn't powering on, taking a look through this guide may be beneficial. Replacing the battery is very simple, requires only a couple steps, one tool, and can be completed fairly quickly. In between removing and replacing the battery, cleaning the compartment out is recommended. The battery compartment has a tendency to collect dust and debris, so cleaning it out may also help the battery last longer.
Was du brauchst
Use your hand to firmly grip the Molex harness and push the clasp open to release the male from the female port.
Remove the battery from the vacuum.
