Einleitung
If your eufy RoboVac 11's side brushes are stuck or having trouble moving debris towards the rolling brush, looking through this guide may be beneficial. Replacing the side brush motors requires some finesse in taking the RoboVac apart. However, the replacement itself is rather simple.
Was du brauchst
Remove the nine 10 mm screws with the Phillips #1 precision screwdriver.
Remove the top plate from the body of the device.
Unplug the bumper from the motherboard.
Remove the 10 mm side brush motor screws with the Phillips #1 screwdriver.
Remove the side brushes.
Remove the side brush motors.
