Einleitung
This is a guide on replacing the charging port on your Eufy SpaceView Baby Monitor. This step-by-step guide will take you through the process of the replacement.
Was du brauchst
Using either the Jimmy or the IFixit Opening tool, press into the opening notches built into the lower portion of the display.
The sides of the display each have two notches, while the top has 3 notches, and the bottom has 4 respectively.
Using the given tools, ensure that the tool enters the space of the opening notches, and apply force downwards, prying that specific part up and away from the housing.
Repeat for all sides and notches, until the display is completely detached from the rest of the monitor.
Lay the display face down on a table, to expose the back of the screen.
Use Phillips #00 screwdriver to unscrew each of the six screws that hold the display in place.
Gently lift the display housing, and set it aside.
The housing is ready to have the new display installed.
Gently disconnect the ribbon connector from the motherboard, taking care not to damage it.
Using a Phillips #00 screwdriver, unscrew the 4 retaining screws in each corner of the motherboard.
Starting with either red/black wired connector on, gently pull it from its receptor and set it aside.
Pull the white ribbon connector from the motherboard, on the side closest to the battery.
Lift the motherboard and disconnect the antenna connector from its port.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
