Zum Hauptinhalt wechseln
eufy Security SpaceView Monitor Screen Replacement
Was du brauchst
  1. eufy Security SpaceView Monitor Screen Replacement, Display Assembly: Schritt 1, Bild 1 von 2 eufy Security SpaceView Monitor Screen Replacement, Display Assembly: Schritt 1, Bild 2 von 2
    • Using either the Jimmy or the IFixit Opening tool, press into the opening notches built into the lower portion of the display.
    • The sides of the display each have two notches, while the top has 3 notches, and the bottom has 4 respectively.
    • Using the given tools, ensure that the tool enters the space of the opening notches, and apply force downwards, prying that specific part up and away from the housing.
    • Repeat for all sides and notches, until the display is completely detached from the rest of the monitor.
  2. eufy Security SpaceView Monitor Screen Replacement: Schritt 2, Bild 1 von 1
    • Lift the display up and away from the housing.
    • Take care to not twist or pull on the ribbon connector.
  3. eufy Security SpaceView Monitor Screen Replacement, Screen: Schritt 3, Bild 1 von 1
    • Lay the display face down on a table, to expose the back of the screen.
    • Use Phillips #00 screwdriver to unscrew each of the six screws that hold the display in place.
    • There are two on each end of the display, and one on each of its longer sides.
  4. eufy Security SpaceView Monitor Screen Replacement: Schritt 4, Bild 1 von 2 eufy Security SpaceView Monitor Screen Replacement: Schritt 4, Bild 2 von 2
    • Gently lift the display housing, and set it aside.
    • The housing is ready to have the new display installed.
  5. eufy Security SpaceView Monitor Screen Replacement: Schritt 5, Bild 1 von 1
    • Gently disconnect the ribbon connector from the motherboard, taking care not to damage it.
Abschluss
ZFarley
395 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2023 Mitglied von UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G5
3 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
Where do you get the replacement screen?
Ronald - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 14
Letzte 30 Tage: 54
Insgesamt: 283
