Einleitung
If all else has failed, now is the time to replace your motherboard in a last attempt to save your laptop.
Was du brauchst
Use a PH000 screwdriver to unscrew the eleven 4mm Phillip head screws located on the back panel.
Using the iFixit opening tool, pry open and remove the back cover of the laptop.
Use a PH000 screwdriver to unscrew the four 3.5mm Philips head screws located on the battery.
Disconnect the port connecting the battery and the motherboard and then remove.
Use a spudger to lift the latch that holds the hard drive cable in place.
Use a PH0 screwdriver to unscrew the three 3 mm Phillips head screws located on the fan.
Use a PH1 screwdriver to unscrew the four 3mm Phillips head screws located on the processor cover.
Disconnect the cable.
Disconnect the plastic arm attached to the processor and remove.
Disconnect the cable attaching the fan to the motherboard and remove.
Use a PH1 screwdriver to unscrew one 3mm Phillips head screws on Wifi card.
Disconnect the Wifi card.
Use a PH1 screwdriver to unscrew six 3 mm Phillips head screws on the motherboard.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Good job Stephany. I would’ve been lost without you…
your friend eternally,
Richey Dale
How can i get this model motherboard
