Einleitung
This guide will show you the steps on how to replace your M.2 NVMe Drive in your iBUYPOWER Trace 4 9310 desktop. The iBUYPOWER Trace 4 9310 comes with 2 SATA ports and 1 M.2 NVMe Drive port.
This guide can be completed within a few minutes, and you only need a small Phillips head screwdriver.
As a precaution, unplug and turn off your computer before working on it.
Was du brauchst
Lay the desktop on its side with the glass panel facing up.
Remove the single screw.
Remove the glass side by pivoting it up with the bottom side still seated in the notches.
Lift the glass side out of the notches and set it to the side.
Locate the M.2 drive that is right above the CPU.
Remove the screw on the edge of the drive.
The drive should lift up on the edge where the screw was.
Pull the drive out at an angle from the motherboard.
Line the new drive up with the slot and gently slide it in.
Use one finger to hold the drive down while you screw it back in.
4 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
Thank you, Kilie, for the clear step-by-step instructions, together with pictures, for NVMe SSD installation.
George
