Einleitung
Internal Prerequisite.
Was du brauchst
Use a 1.5 mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
Insert the flat end of a spudger into the gap between the front and rear bezels.
Rotate your spudger until it is parallel to the front face of the display.
Run the spudger around the perimeter of the display to separate the rear bezel from its retaining clips.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
