Zum Hauptinhalt wechseln
iBook G4 14" 1.42 GHz Battery Connector Replacement
Was du brauchst
  1. iBook G4 14" 1.42 GHz Battery Connector Replacement, Battery: Schritt 1, Bild 1 von 2 iBook G4 14" 1.42 GHz Battery Connector Replacement, Battery: Schritt 1, Bild 2 von 2
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
  2. iBook G4 14" 1.42 GHz Battery Connector Replacement, Lower Case: Schritt 2, Bild 1 von 1
    • Close the display and flip the computer over.
    • Remove the three hex screws using a T8 Torx screwdriver.
    • The shorter screw is in the center.
  3. iBook G4 14" 1.42 GHz Battery Connector Replacement: Schritt 3, Bild 1 von 1
    • Use a spudger or small flathead screwdriver to remove the three rubber feet from the lower case.
  4. iBook G4 14" 1.42 GHz Battery Connector Replacement: Schritt 4, Bild 1 von 1
    • Remove the three newly-revealed Phillips screws.
    • One screw is underneath each bumper (three total).
  5. iBook G4 14" 1.42 GHz Battery Connector Replacement: Schritt 5, Bild 1 von 1
    • Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
  6. iBook G4 14" 1.42 GHz Battery Connector Replacement: Schritt 6, Bild 1 von 1
    • Remove the two Phillips screws on either side of the battery contacts.
  7. iBook G4 14" 1.42 GHz Battery Connector Replacement: Schritt 7, Bild 1 von 1
    • Breathe deeply. Trying times are ahead, but we promise the lower case does come off.
    • Push in the thin rims of the lower case surrounding the battery compartment, bending them past the tabs, and then lift up to free that corner of the lower case.
  8. iBook G4 14" 1.42 GHz Battery Connector Replacement: Schritt 8, Bild 1 von 1
    • There is a slot on the wall of the battery compartment that locks the lower case in place. Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
  9. iBook G4 14" 1.42 GHz Battery Connector Replacement: Schritt 9, Bild 1 von 1
    • Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case. Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
  10. iBook G4 14" 1.42 GHz Battery Connector Replacement: Schritt 10, Bild 1 von 1
    • Continue to run the spudger around the front, right corner. There are two tabs on the port side of the computer, one near the front corner and one near the sound-out port.
  11. iBook G4 14" 1.42 GHz Battery Connector Replacement: Schritt 11, Bild 1 von 1
    • There are three tabs over the optical drive that must be released before the lower case can come off. Slide the spudger into the lower case above the optical drive and run it toward the back of the computer until you hear three distinct clicks.
  12. iBook G4 14" 1.42 GHz Battery Connector Replacement: Schritt 12, Bild 1 von 1
    • The front and sides of the lower case are now free.
    • Turn the computer so that the back is facing you and pull the lower case up and toward you until the back tabs pop free.
    • It may be helpful to jiggle the case up and down.
  13. iBook G4 14" 1.42 GHz Battery Connector Replacement: Schritt 13, Bild 1 von 1
    • Remove the small greasy springs with white plastic caps from either side of the battery contacts.
  14. iBook G4 14" 1.42 GHz Battery Connector Replacement, Bottom Shield: Schritt 14, Bild 1 von 1
    • Remove the following 10 screws from the bottom shield:
    • Six 3 mm Phillips
    • Three 7.5 mm Phillips
    • One 14 mm Phillips
  15. iBook G4 14" 1.42 GHz Battery Connector Replacement: Schritt 15, Bild 1 von 1
    • Lift the bottom shield off.
  16. iBook G4 14" 1.42 GHz Battery Connector Replacement, Battery Connector: Schritt 16, Bild 1 von 1
    • Remove the two Phillips screws securing the battery connector to the metal framework.
  17. iBook G4 14" 1.42 GHz Battery Connector Replacement: Schritt 17, Bild 1 von 1
    • Lift the battery connector out of the metal framework and disconnect it from the logic board.
    • This connector requires considerable force to remove. We recommend wiggling the connector while applying tension to slowly "walk" the connector out of its socket.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Angehängte Dokumente
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 17
Insgesamt: 8,150
