Einleitung
Replace your broken display hinges to make your display open silky-smooth.
Use a coin to rotate the battery locking screw 90 degrees clockwise.
Lift the battery out of the computer.
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
Push the wire clasp away from the AirPort card and toward the display, then rotate up to free it from the RAM shield.
Grasp the clear plastic tab on the AirPort card and pull toward the display.
Hold the AirPort card in one hand and use your other hand to remove the antenna cable.
Remove the four silver Phillips screws that secure the RAM shield.
Grasp the metal bracket on top of the RAM shield and pull upward to remove the shield.
Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
Use a pin (or anything you like) to remove the three rubber feet from the lower case.
Remove the three newly-revealed Phillips screws.
Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
Remove the three hex screws using a T8 Torx screwdriver (or Allen screws using an Allen key if these are used).
Quote from dalekaty:
Why use a T8 Torx when these screws are metric hex 2? The T8 didn't work at all. Other than that this was a very easy repair. It cost $29 instead of the $150 that I paid the last time a Mac shop made the same repair.
Had the same issue with a T8, although I blamed that on my T8 being quite stripped. Finding an appropriate bit was quite a challenge... but I'm pretty certain a T8 isn't correct. The screws have a hex head, not a Torx... maybe T8 is the closest thing that tends to fit...
Not Torx, but allen key (British wrench), 2mm
I attempted this last night following all the steps correctly, when I was done my ibook would not turn on. Now sure where I went wrong? Any ideas. Thank you
Remove the two Phillips screws on either side of the battery contacts.
Push the thin rims of the lower case surrounding the battery compartment in, bending them past the tabs, and then lift up to free that corner of the lower case.
I printed these instructions out, and this one was at the top of page 2. I found the first paragraph amusing enough that I had to show my boss.
There is a slot on the wall of the battery compartment that locks the lower case in place. Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case. Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
Continue to run the spudger around the front, right corner. There are two tabs on the port side of the computer, one near the front corner and one near the sound-out port.
For me, this was really the toughest part! Trying to find/get a good grip on the iBook and really *forcing* that spudger around. All without scratching the display.
Once you loosen the the front the seam is very tight. I was able to slide the spudger in the middle of the port side instead of starting at the corner.
There are three tabs over the optical drive that must be released before the lower case can come off. Slide the spudger into the lower case above the optical drive and run it toward the back of the computer until you hear three distinct clicks.
Once the front and sides of the lower case are free, turn the computer so that the back is facing you and pull the lower case up and toward you until the back tabs pop free (it may be helpful to jiggle the case up and down).
This was the scariest part for me. I had to wiggle it a lot as it seemed to be stuck. But it did come loose.
Remove the small greasy springs with white plastic caps from either side of the battery contacts.
Remove the following 10 screws from the bottom shield:
Six 3 mm Phillips
Three 7.5 mm Phillips
One 14 mm Phillips
Lift the bottom shield off.
My dc board had 2 screws. for some reason when i tried to screw them both back in only one got tight. the other one just kept twirling so i left it out. i didnt want to have a loose screw rattling around in my computer.
also had trouble laying down the wire to the dc board. it wouldnt lay flat but i was able to get it flat enough. overall it worked and the computer is now up and running!
thank you! it was pretty easy
Remove the single Phillips screw securing the DC-In board.
At this point alternate hard drive can be connected to logic board for testing. Alternate hard drive and drive cable req'd. Remove hard drive cable from logic board. Plug in alternate cable and drive.
Disconnect the DC-In cable from the logic board.
Deroute the cable from around the optical drive, removing tape as necessary, and angle the DC-In board out of its compartment.
Went pretty smoothly as described. I used an egg crate marked for each step where screws were removed to keep them all sorted out (OCD vs. old age). Only other tip was that in step #5 the rings and screws at the corners of the back seemed to be integrated and came out together, the rubber feet came up by pulling from the side - didn't really require a thumb tack. Otherwise, having the right tools (described) made it a snap.
Quote from drscole:
I agree - having the right tools is the key to this going smoothly. It would have useful to have more detail around where the long and short screws go on the heat shield. This is minor niggle and overall good instructions.
Quote from drscole:
The egg crate is a good idea. I use a piece of cardboard and I label each step and layout the screws visually as I pulled them out.
Remove the following 11 screws from the bottom of the computer:
Three 3 mm Phillips around the battery compartment. (Some models may only have two screws.)
Three 4.5 mm Phillips along the optical drive bezel. (a magnetic screwdriver may help to lift these screws out)
One 11 mm Phillips in the lower right corner. (if present)
Four 14.5 mm Phillips.
The middle screw along the optical drive got sucked sideways into an opening by something magnetic and proved impossible to get out with a bit of blutack on the end of a screwdriver. In the end turning it over and giving it a smart tap worked.
Turn over the computer and open it.
Remove the 2 Phillips screws (3mm) from the edges of the keyboard area.
Remove the 4 mm Phillips screw from the lower left corner.
Lift the upper case and use a spudger or your finger to disconnect the trackpad connector hidden beneath the white plastic tab. Due to model variatons your trackpad connector may be different than the one pictured.
Carefully lift the upper case about half of an inch and move it so that you can access the power and speaker cables.
Lift the upper case enough to disconnect the blue and white power cable from the logic board. Using your fingernails or a dental pick, carefully pry the connector from its socket. Make sure you're pulling only on the connector and not on the socket.
I skipped this and the next step altogether. Instead of taking the risk of breaking the power and/or speaker sockets, I left them connected. I put a stack of big books just to the left of the iBook. I swiveled the top case off and let it lean against the books. I removed the top shield and carefully swiveled it off and to the left, so it is now leaning on the top case. I had to move the power cable out of the way, and re-orient the top case so it's resting on it's back edge while the shield was resting on it's left edge. Then I slid the iBook towards the edge of the table and disconnected the HD ribbon from below! I then proceeded with removing the HD and putting in the new one.
When putting the rings back you will need to figure out their correct orientation. Just rotate each ring until you find the position that will make it flush with the case. There are three possible positions but only one of them is the right fit.
As the other comments make plain, you can't overemphasize that the power connector is in tight, and it is much easier to pull the connector off the board. That's what happened to me -- I'm really bad at soldering, so I will be looking for a replacement board. Oh well.
Carefully disconnect the multicolored speaker cable from the logic board. As before, make sure you're pulling only on the connector and not on the socket.
Remove the following 16 screws:
Thirteen 3 mm Phillips.
One 3 mm Phillips. (actual screw not present in image)
Two 4 mm Phillips.
Missing in this photo is the Bluetooth antenna present in some iBooks. It is located at the upper right corner of the battery compartment, just above the 4mm screw. You can see the bracket for the antenna in the photo. It is the two I-shaped holes just above the 4mm screw that must be removed in this step. To remove the antenna, slide it toward the LCD, and tilt it vertically back towards yourself. In the next step, where the shield is removed, you will need to slide the antenna through the lower I-shaped hole.
Lift the top shield up from the right side, minding the upper left corner, which may catch on the metal framework.
If your iBook has Bluetooth, as discussed in the previous step, you will need to slide the antenna through the lower I-shaped hole in the shield before completely removing the shield.
Remove the two Phillips screws at the corners of the modem.
Lift the modem and modem shield from the bottom.
Disconnect the RJ-11 cable from the top of the modem.
Turn the computer over.
Disconnect the inverter cable from the logic board and deroute it from the metal framework, removing tape as necessary.
Turn the computer back over.
Disconnect the microphone cable at the front of the computer, between the left side of the hard drive and the metal framework.
The side of the case has a alight recess that the connector fits in. Pulling the case out lets it come out more easily.
Quote from tatterjack:
The side of the case has a slight recess that the connector fits in. Pulling the case out lets it come out more easily.
Use the black plastic loop to disconnect the display data cable from the logic board.
Deroute the microphone and display data cables from the metal framework, removing tape as necessary.
Deroute the AirPort antenna cable from the metal framework, removing tape as necessary.
Support the display with one hand and remove the single Phillips screw on either side of the hinge (two screws total).
Lift the display up and tilt it backwards, freeing it from the two metal alignment posts holding the hinges in place, and slide it away from you.
Use a 1.5 mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
Use your thumbs to slightly separate the rear bezel from the front bezel.
Insert the flat end of a spudger into the gap between the front and rear bezels.
Rotate your spudger until it is parallel to the front face of the display.
Run the spudger around the perimeter of the display to separate the rear bezel from its retaining clips.
Lift the rear bezel off the display.
Remove the pieces of readily removable tape from around the perimeter of the display.
Carefully remove the aluminum tape covering the display data cable connection.
Remove the single screw inserted through the piece of EMI tape near the bottom edge of the display.
Use the tip of a spudger to remove the small washer under the screw you just removed.
Peel the aluminum/EMI tape off the cast aluminum frame of the clutch hinges.
Remove the two Phillips screws securing each side of the LCD to the clutch hinge frame (four screws total).
Lift the thin steel LCD cover off the LCD.
Remove the second of the two Phillips screws securing the clutch cover to the cast aluminum frame of the clutch hinges.
Pull the clutch cover away from the front of the display.
Remove the pieces of tape covering the display data and microphone cables near the bottom edge of the display.
Disconnect the display data cable by pulling its connector away from the socket on the LCD.
Remove the display data cable from the display.
Use the tip of a spudger to lift the microphone out of the front bezel.
De-route the microphone cable from around the top and side of the display.
Remove the two pieces of tape covering the inverter/AirPort cables along the lower edge of the display.
Carefully peel the inverter cable ground strap off the cast aluminum frame of the clutch hinges.
Disconnect the backlight cable from the inverter.
Lift the LCD out of the display assembly.
Remove the single Phillips screw securing the reed switch board to the front bezel.
Carefully lift the reed switch board off the metal frame of the clutch hinges.
Remove the two Phillips screws securing the right AirPort antenna to the clutch hinge frame.
Carefully lift the right AirPort antenna off the clutch hinge frame.
Remove the two Phillips screws securing the left AirPort antenna to the clutch hinge frame.
Carefully lift the left AirPort antenna off the clutch hinge frame.
Use the flat end of a spudger to remove the antenna board from the front bezel.
Remove the single Phillips screw securing the front bezel to the middle of the cast aluminum clutch hinge frame.
Carefully bend the front display bezel away from the clutch hinges as you slide the two AirPort antennas out from under the clutch hinge frame.
While pulling the inverter cable away from its socket on the inverter board, use the tip of a spudger to push the connector out of its socket.
Remove the six Phillips screws securing the clutch hinges to the front display bezel.
Lift the clutch hinges off the front display bezel.
2 weitere Nutzer haben diese Anleitung absolviert.
