Einleitung
This guide demonstrates how to remove and replace the button keys of am iDea USA CT702 in order to preserve the function of the device.
Was du brauchst
Place the device face up.
Use a plastic opening tool to gently pry open the black panel around the portholes.
Pry the rest of the back off; slowly apply pressure from each side to break each clip connection.
With a plastic spudger tool, pry the keys away from the black key mat to remove them.
Replace the button keys, starting with the outer and ending with the innermost key.
To replace the back cover, follow the first three steps in reverse order.
