Zum Hauptinhalt wechseln
iDea USA CT702 Microphone Replacement
Was du brauchst
  1. iDea USA CT702 Microphone Replacement, Microphone: Schritt 1, Bild 1 von 1
    • Place the tablet face up with portholes facing you.
  2. iDea USA CT702 Microphone Replacement: Schritt 2, Bild 1 von 2 iDea USA CT702 Microphone Replacement: Schritt 2, Bild 2 von 2
    • Use a fingernail, or a plastic opening tool to gently pry the black panel around the portholes.
    • Be gentle and take your time. Excessive force could damage the device.
  3. iDea USA CT702 Microphone Replacement: Schritt 3, Bild 1 von 3 iDea USA CT702 Microphone Replacement: Schritt 3, Bild 2 von 3 iDea USA CT702 Microphone Replacement: Schritt 3, Bild 3 von 3
    • Use your fingers to pry the rest of the back off; slowly apply pressure from each side to break each clip connection.
  4. iDea USA CT702 Microphone Replacement: Schritt 4, Bild 1 von 1
    • Once the back is off, position the tablet as shown and be sure to warm your soldering iron.
  5. iDea USA CT702 Microphone Replacement: Schritt 5, Bild 1 von 1
    • Place tip of the soldering iron on the end of the wire to break connection.
    • Remember to use proper safety precautions when soldering.
  6. iDea USA CT702 Microphone Replacement: Schritt 6, Bild 1 von 1
    • Grip the new microphone with tweezers and place in the slot.
    • Solder the new connections while using tweezers to hold the speaker steady.
Abschluss
Benton Gray
201 Reputation
2 Anleitungen geschrieben
Colorado Springs, Team 4-7, Panko Spring 2015 Mitglied von Colorado Springs, Team 4-7, Panko Spring 2015
UCCS-PANKO-S15S4G7
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 111
