Einleitung
This is where you learn how to replace a power button.
Was du brauchst
Place the tablet on a flat surface, facing upwards.
Starting from the portholes, use the plastic opening tools to remove the back cover of the tablet from the top half.
Being cautious of the wire connecting the speaker and the motherboard, place the front and back portion of the tablet close in proximity.
On the tablet’s back cover, locate the power button.
Use tweezers to remove button’s padding that holds it in place.
To remove the power button, use a plastic opening tool to nudge the button out of position.
A gentle push from the button’s exterior side should be enough.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
