Einleitung
Consider this a meta-guide...that is, a guide that enables other guides. Before you remove any screws, you need to use the right bit, but getting those out of the tightly packed storage area and into your driver can be a chore in itself.
Was du brauchst
Note how challenging it is to remove a required bit from the kit. Argh!
Wrap said band around the bit and viola! easy bit extraction enabled. You might want to keep that handy rubber band with the kit now.
Alternate, no-rubber-band solution: use the tweezers supplied in the bit driver kit.
48 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
I want to order the 26 bit driver kit technique for removing bits
