Was du brauchst
Use your fingers to slide the battery case cover off in the direction of the arrows.
Remove the four AAA batteries. Be sure to check your nearest battery recycling point!
Unscrew the four outer 1.0 mm screws with a Phillips-Head screwdriver.
Push down gently on the battery case cover and slide it in the direction the arrows indicate. Remove the batteries.
Unscrew the 0.6 mm screw located in the center of the battery case.
Keep the 1.0 mm and 0.6 mm screws separate from each other for reassembly.
Remove the back cover carefully; there are many wires that connect it to the device.
Locate the two small connection points for the stand.
Using small needle nose pliers, pinch the end of the stand toward the side of the speaker case.
Pop the end of the stand out of the hole in the side of the speaker case.
Repeat this step for the opposite side of the stand.
1. Position the new stand perpendicular to the speaker case.
2. Align the bulbs at the end of the stand with the holes in the side of the speaker case.
3. Gently push the bulbs into the holes of the speaker case.
4. Pull the stand back around the speaker system.
