Zum Hauptinhalt wechseln
iHip Fold-up Portable Speaker Back Cover Removal
Was du brauchst
  1. iHip Fold-up Portable Speaker Back Cover Removal, Removing the battery case cover: Schritt 1, Bild 1 von 1
    • Use your fingers to slide the battery case cover off in the direction of the arrows.
  2. iHip Fold-up Portable Speaker Back Cover Removal, Cleaning the battery case: Schritt 2, Bild 1 von 3 iHip Fold-up Portable Speaker Back Cover Removal, Cleaning the battery case: Schritt 2, Bild 2 von 3 iHip Fold-up Portable Speaker Back Cover Removal, Cleaning the battery case: Schritt 2, Bild 3 von 3
    • Remove the four AAA batteries. Be sure to check your nearest battery recycling point!
    • Use the detailing brush and a paper towel to remove any corrosion left by previous batteries.
  3. iHip Fold-up Portable Speaker Back Cover Removal, Removing the screws: Schritt 3, Bild 1 von 2 iHip Fold-up Portable Speaker Back Cover Removal, Removing the screws: Schritt 3, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Unscrew the four outer 1.0 mm screws with a Phillips-Head screwdriver.
    • Screws will be magnetized in position and will require the use of tweezers to be removed.
    • Push down gently on the battery case cover and slide it in the direction the arrows indicate. Remove the batteries.
    • Unscrew the 0.6 mm screw located in the center of the battery case.
    • Keep the 1.0 mm and 0.6 mm screws separate from each other for reassembly.
  4. iHip Fold-up Portable Speaker Back Cover Removal, Removing the back cover: Schritt 4, Bild 1 von 2 iHip Fold-up Portable Speaker Back Cover Removal, Removing the back cover: Schritt 4, Bild 2 von 2
    • Remove the back cover carefully; there are many wires that connect it to the device.
Abschluss
Cristina Garcia
301 Reputation
3 Anleitungen geschrieben
Clemson, Team 3-4, Benson Fall 2014 Mitglied von Clemson, Team 3-4, Benson Fall 2014
CLEM-BENSON-F14S3G4
5 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 298
