Einleitung
This guide will assist users in removing and replacing the power switch on the iHome iBT16 device.
Was du brauchst
Using the Philips #00 Screwdriver, unscrew and remove the four 9mm black screws on the base plate of the device.
Using the plastic opening tool, insert into the crack between the base plate and the main body of the device
Using a lever like motion, push the opening tool down thus lifting the plate
Using the Philips #00 screwdriver, unscrew and remove the two silver 10mm screws holding the motherboard
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
