Einleitung
Use this guide to remove the AC power adapter. For help troubleshooting click the link to our troubleshooting page iHome IH11 Troubleshooting.
Was du brauchst
Unscrew the two 9.0 mm screws with the Phillips #1.
Remove the translucent bottom plastic piece.
Remove the two 9.0mm screws on the back of the iHome with the Phillips #1 screwdriver.
Repeat the previous step for the two 9.0mm screws on the bottom.
Remove the aluminum bracket by loosening the two nuts and removing the 8.0mm bolts with your hand.
Remove the two 12.0mm screws that hold the motherboard with the Phillips #1 screwdriver.
Slide the motherboard gently out.
Remove the two 9.0 mm screws with the Phillips #1 screwdriver, then slide the circuit board for the AC adapter out.
Repeat the previous step by removing the two 9.0mm screws with the Phillips #1 screwdriver for the circuit board for the on/off switch.
Unsolder the main connections holding the AC adapter to the circuit board.
Solder new adapter in same position with same connections.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
