Zum Hauptinhalt wechseln
iHome iAVS16 LCD (Display) Replacement
Was du brauchst
  1. iHome iAVS16 LCD (Display) Replacement, Power Board: Schritt 1, Bild 1 von 3 iHome iAVS16 LCD (Display) Replacement, Power Board: Schritt 1, Bild 2 von 3 iHome iAVS16 LCD (Display) Replacement, Power Board: Schritt 1, Bild 3 von 3
    • Remove the four 1.7 mm Phillips #0 screws located on the bottom of the device.
    • Lift up the bottom of the device.
    • Carefully lift the bottom of the device up as to not damage the ribbon cable connecting it.
  2. iHome iAVS16 LCD (Display) Replacement: Schritt 2, Bild 1 von 3 iHome iAVS16 LCD (Display) Replacement: Schritt 2, Bild 2 von 3 iHome iAVS16 LCD (Display) Replacement: Schritt 2, Bild 3 von 3
    • Remove the two 1.7 mm Phillips #0 screws holding the white face place onto the inside of the device's bottom.
    • Using an iFixit opening tool on the side without the black adhesive, carefully lift up the white face plate.
    • Lifting too quickly could damage the ribbon cable still attached.
  3. iHome iAVS16 LCD (Display) Replacement: Schritt 3, Bild 1 von 2 iHome iAVS16 LCD (Display) Replacement: Schritt 3, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Using the tweezers, lift up on the black tab holding the ribbon cable down.
    • Carefully pull the ribbon cable back and out of the slot.
  4. iHome iAVS16 LCD (Display) Replacement: Schritt 4, Bild 1 von 3 iHome iAVS16 LCD (Display) Replacement: Schritt 4, Bild 2 von 3 iHome iAVS16 LCD (Display) Replacement: Schritt 4, Bild 3 von 3
    • Remove the two 1.7 mm Phillips #0 screws holding the power board in.
    • Carefully flip the board over.
    • Remove the red connector from its socket with a pair of tweezers.
  5. iHome iAVS16 LCD (Display) Replacement, LCD (Display): Schritt 5, Bild 1 von 3 iHome iAVS16 LCD (Display) Replacement, LCD (Display): Schritt 5, Bild 2 von 3 iHome iAVS16 LCD (Display) Replacement, LCD (Display): Schritt 5, Bild 3 von 3
    • Insert an iFixit opening tool into the lining on the front casing and pry it apart. Do this for both sides.
    • Further remove the front casing off from the device manually with your hands.
  6. iHome iAVS16 LCD (Display) Replacement: Schritt 6, Bild 1 von 1
    • Remove the four 1.7 mm Phillips #0 screws holding the LCD onto the front of the device.
  7. iHome iAVS16 LCD (Display) Replacement: Schritt 7, Bild 1 von 3 iHome iAVS16 LCD (Display) Replacement: Schritt 7, Bild 2 von 3 iHome iAVS16 LCD (Display) Replacement: Schritt 7, Bild 3 von 3
    • Carefully flip the LCD display over to expose the ribbon cable connecting it.
    • Lift the black tab holding the cable down, and carefully put it out of the socket.
Abschluss
Marco Sousa
293 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S1-G7, O'Connell Fall 2019 Mitglied von UMass Dartmouth, Team S1-G7, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G7
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 13
Insgesamt: 187
