Einleitung
Are you interested in improving the Wi-Fi reception on your iHome iAVS16? This guide will show you how to disassemble the iHome iAVS16 to access the Wi-Fi antenna for replacement.
The iHome iAVS16 is a clock and speaker system with Amazon Alexa capabilities. The device uses a Link Play A31 Wi-Fi module for playing audio content via a wireless Internet connection. Replacing the attached antenna could help to improve the Wi-Fi reception.
You may wish to remove the motherboard for easier access to the Wi-Fi chip. If so, the motherboard guide provides instructions for that process.
Before beginning, make sure to power off the device completely and disconnect from any external power source.
Was du brauchst
Remove the four 1.7 mm Phillips #0 screws located on the bottom of the device.
Lift up the bottom of the device.
Remove the two 1.7 mm Phillips #0 screws holding the white face place onto the inside of the device's bottom.
Using an iFixit opening tool on the side without the black adhesive, carefully lift up the white face plate.
Remove the two 1.7 mm Phillips #0 screws holding the power board in.
Carefully flip the board over.
Remove the red connector from its socket with a pair of tweezers.
Insert an iFixit opening tool into the lining on the front casing and pry it apart. Do this for both sides.
Further remove the front casing off from the device manually with your hands.
Remove the four 1.7 mm Phillips #0 screws holding the LCD onto the front of the device.
Carefully flip the LCD display over to expose the ribbon cable connecting it.
Lift the black tab holding the cable down, and carefully put it out of the socket.
Using an iFixit opening tool, push the tab under the top of the device to create a gap.
Insert the iFixit opening tool in the gap, and slide it across to remove the top casing.
Remove the top cover of the device.
Remove the five 1.7 mm Phillips #0 screws on the top of the device.
