Zum Hauptinhalt wechseln
iHome iBT84 Motherboard Replacement
Was du brauchst
  1. iHome iBT84 Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 2 iHome iBT84 Motherboard Replacement, Motherboard: Schritt 1, Bild 2 von 2
    • On the opposite side of the speaker should be a sticker, remove it with your fingers or the flat plastic iFIxit tool.
    • Use a Philip's screwdriver to take the screws out of the cover.
  2. iHome iBT84 Motherboard Replacement: Schritt 2, Bild 1 von 2 iHome iBT84 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Once the screws are all out, the cover should come off revealing the motherboard.
  3. iHome iBT84 Motherboard Replacement: Schritt 3, Bild 1 von 3 iHome iBT84 Motherboard Replacement: Schritt 3, Bild 2 von 3 iHome iBT84 Motherboard Replacement: Schritt 3, Bild 3 von 3
    • You will notice that the triangular black volume piece is loose, make sure to take that off revealing the buttons.
    • Once that is done, the motherboard can be taken out. May require some wiggling.
    • Make sure none of the wires are damaged and that they are all connected.
  4. iHome iBT84 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • The connections shown here can be taken off by pulling on the white plastic connector piece.
    • The same can be said about the white, paper like, connectors. Pull on them gently.
    • Once all connections are apart, the motherboard is safe to be replaced.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 10
Insgesamt: 967
