Einleitung
Replace your iPod adapter if it's broken so you can charge your iPad/iPod/iPhone or play songs on the iD95.
Ersatzteile
Kein Ersatzteil erforderlich.
Before taking apart the iD95, disconnect the AC cord from the wall socket and AC adapter from the DC jack. Remove any iPods, iPhones, and iPads attached to the device.
Flip over the iD95 so the bottom cover is visible and the LCD screen is facing you.
Unscrew five 17 mm-length, 6 mm-head screws using a Phillips #1 screwdriver.
Insert a plastic opening tool between the edge of the bottom cover and the main body.
Gently pry the bottom cover from the body. Start anywhere along the front side of the iD95 and work your way around.
Grip the bottom portion of the device and gently lift the front part of the bottom cover a couple centimeters up.
Lift up the bottom cover. Pull the side panel up first, out, and away from the device.
The side panels have plastic rings that will need to be lifted up and off the cylinders they are placed around.
Apply the same techniques from the previous step to remove the remaining side panel.
Locate the two plastic clips holding the bottom and back cover together.
Which clip you remove first is up to you. Rotate the device 90 degrees either left or right. Insert the flat end of a spudger horizontally between the back speaker and the back cover.
Place the flat end of the spudger behind one clip and pry it open. This may take repeated attempts.
Use a plastic opening tool to pry off the white zip connector joining the wires to the logic board.
Use a plastic opening tool to lift the two speaker zip connectors from the logic board.
Flip the logic board over.
Use a plastic opening tool to pry and lift the iPod adapter zip connector from the logic board.
Remove two 4 mm-head 12 mm-length screws using a Phillips #1 screwdriver.
Pull the iPod adapter from the top cover.
Use a Phillips #1 screwdriver to take out the two, 12 mm-length 4 mm-head, screws holding the iPod adapter to its casing.
