Zum Hauptinhalt wechseln
iHome iH27B iPod Adapter Replacement
Was du brauchst
  1. iHome iH27B iPod Adapter Replacement, Adapter: Schritt 1, Bild 1 von 1
    • Set the IHome on a surface facing upward.
    • Locate the two screws on the docking station adapter.
    • Remove the following screws:
    • Two 10 mm Phillips #0
  2. iHome iH27B iPod Adapter Replacement: Schritt 2, Bild 1 von 1
    • Grip the plastic adapter case and pull upwards with a medium amount of force. You will have to twist forward a little so that the connections are visible.
    • The adapter will still be connected with wires, so make sure not to pull too hard.
  3. iHome iH27B iPod Adapter Replacement: Schritt 3, Bild 1 von 3 iHome iH27B iPod Adapter Replacement: Schritt 3, Bild 2 von 3 iHome iH27B iPod Adapter Replacement: Schritt 3, Bild 3 von 3
    • Four 7 mm Phillips #0
    • Lift up the two black plastic pieces that have come loose on either side of the circuit board, and set them aside.
  4. iHome iH27B iPod Adapter Replacement: Schritt 4, Bild 1 von 2 iHome iH27B iPod Adapter Replacement: Schritt 4, Bild 2 von 2
    • Carefully pry apart the bundle of white wires connected at the junction with the plastic opening tool.
    • Do this slowly. Be careful not to damage the wires
    • Lift up the circuit board that has become loose.
  5. iHome iH27B iPod Adapter Replacement: Schritt 5, Bild 1 von 1
    • Pull out the adapter, and replace it with the new one.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
John Kraemer
76 Reputation
9 Anleitungen geschrieben
Cal Poly, Team 3-21, Amido Fall 2012 Mitglied von Cal Poly, Team 3-21, Amido Fall 2012
CPSU-AMIDO-F12S3G21
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 2,336
