Einleitung
The iHome IH27B is a portable alarm clock and sound system. This device acts as a dock for the following devices: iPhone 8, 9 and 10. Placing your iPod on and off of the adapter can cause some normal wear and tear to the dock connector. If you have noticed that your dock connector on the dock is loose or appears to be damaged, you may need to replace the iPod connector.
Was du brauchst
Set the IHome on a surface facing upward.
Locate the two screws on the docking station adapter.
Remove the following screws:
Two 10 mm Phillips #0
Grip the plastic adapter case and pull upwards with a medium amount of force. You will have to twist forward a little so that the connections are visible.
Four 7 mm Phillips #0
Lift up the two black plastic pieces that have come loose on either side of the circuit board, and set them aside.
Carefully pry apart the bundle of white wires connected at the junction with the plastic opening tool.
Lift up the circuit board that has become loose.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
