Zum Hauptinhalt wechseln
iHome iH5 Charging Dock Replacement
Was du brauchst
  1. iHome iH5 Charging Dock Replacement, Charging Dock: Schritt 1, Bild 1 von 1
    • Remove the eight 5/16 inch screws with a #2 Phillips screwdriver.
  2. iHome iH5 Charging Dock Replacement: Schritt 2, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use tweezers to unplug the three wires connected to the circuit board. If the wires are tight pliers might work better.
  3. iHome iH5 Charging Dock Replacement: Schritt 3, Bild 1 von 1
    • Remove the five 5/16 inch screws from the circuit board.
  4. iHome iH5 Charging Dock Replacement: Schritt 4, Bild 1 von 2 iHome iH5 Charging Dock Replacement: Schritt 4, Bild 2 von 2
    • Flip the circuit board over.
    • There are capacitors all over the back side of the board. Be careful not to touch these capacitors (blue cylinders) as they can discharge—giving you a shock.
    • Unplug the eight wires attached to the circuit board with tweezers. If the wires are tight pliers might work better.
    • There is on wire in the orange box.
    • There are two wires in the yellow box.
    • There are five wires in the green box.
  5. iHome iH5 Charging Dock Replacement: Schritt 5, Bild 1 von 1
    • Remove the following four screws securing the iHome iH5 charging dock.
    • Use a #2 Phillips screwdriver to remove the four screws.
  6. iHome iH5 Charging Dock Replacement: Schritt 6, Bild 1 von 1
    • Gently remove the charging dock from the iHome iH5 by pulling it up.
  7. iHome iH5 Charging Dock Replacement: Schritt 7, Bild 1 von 1
    • Remove the final screws connecting the iH5 charging dock to the plastic holding platform
    • Use a #2 Phillips screwdriver to remove the 3/8 inch screws.
  8. iHome iH5 Charging Dock Replacement: Schritt 8, Bild 1 von 1
    • Replace the old iH5 charging dock with new iH5 charging dock.
Abschluss
Dustin Lamb
103 Reputation
1 Anleitung geschrieben
New Mexico State, Team 1-6, Easley Spring 2014 Mitglied von New Mexico State, Team 1-6, Easley Spring 2014
NMSU-EASLEY-S14S1G6
5 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 15
Insgesamt: 965
