Einleitung
This is a replacement guide for the charging dock on the iHome iH5.
Was du brauchst
Remove the eight 5/16 inch screws with a #2 Phillips screwdriver.
Use tweezers to unplug the three wires connected to the circuit board. If the wires are tight pliers might work better.
Flip the circuit board over.
Unplug the eight wires attached to the circuit board with tweezers. If the wires are tight pliers might work better.
There is on wire in the orange box.
There are two wires in the yellow box.
There are five wires in the green box.
Remove the following four screws securing the iHome iH5 charging dock.
Use a #2 Phillips screwdriver to remove the four screws.
Remove the final screws connecting the iH5 charging dock to the plastic holding platform
Use a #2 Phillips screwdriver to remove the 3/8 inch screws.
