Einleitung
This is a cleaning and replacement guide for the iHome iH5.
Was du brauchst
Remove the cover to expose the inside.
With pliers, or tweezers,if needed, remove the three wire harnesses by gently pulling straight up on them.
Remove all wire harnesses from the bottom of the board. There eight wire harnesses.
Remove the two screws from the speakers with a #2 Phillips screwdriver.
Turn the device on its front side and remove the two screws with a #2 Phillips screwdriver.
Pull the speaker up from the back as shown with the speaker on the right. Then pull the speaker straight back as shown with the speaker on the left.
Remove the front piece by pulling up until it hits the plastic pieces sticking out from the display screen. Then pull it out horizontally from the device.
Pull back the circuit board to access the plastic piece.
Lift to separate the plastic piece from the dial.
Replace the broken piece.
3 weitere Personen haben diese Anleitung absolviert.
