Zum Hauptinhalt wechseln
iHome iP1 Motherboard Replacement
Was du brauchst
  1. iHome iP1 Motherboard Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Orient the iHome upside down with the speakers facing away from you.
  2. iHome iP1 Motherboard Replacement: Schritt 2, Bild 1 von 2 iHome iP1 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Remove the four 9.5 mm Phillips #2 screws located on each of the four corners of the iHome's back cover.
  3. iHome iP1 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Remove the back cover by grabbing its sides and lifting it off the iHome.
  4. iHome iP1 Motherboard Replacement, Motherboard: Schritt 4, Bild 1 von 2 iHome iP1 Motherboard Replacement, Motherboard: Schritt 4, Bild 2 von 2
    • Disconnect all five wire bundles attached to the motherboard by pulling them away from their connection.
    • The order in which the wire bundles are removed does not matter.
    • You may need to remove some black foam tape in order fully disconnect some of the wires.
  5. iHome iP1 Motherboard Replacement: Schritt 5, Bild 1 von 2 iHome iP1 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Unscrew the four 9.5 mm Phillips #2 screws on the four metal brackets located at each corner of the motherboard.
  6. iHome iP1 Motherboard Replacement: Schritt 6, Bild 1 von 2 iHome iP1 Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Unscrew the grey 6.0 mm Phillips #1 screw directly above the red, blue, and green component ports.
  7. iHome iP1 Motherboard Replacement: Schritt 7, Bild 1 von 3 iHome iP1 Motherboard Replacement: Schritt 7, Bild 2 von 3 iHome iP1 Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Remove the motherboard from its housing by grabbing it near its edges and carefully pulling it upward.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Sachin Shenoi
333 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 20-1, Livingston Fall 2016 Mitglied von Cal Poly, Team 20-1, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G1
4 Mitglieder
7 Anleitungen geschrieben
5 Kommentare
Easy to do,
but where can i buy a new motherboard ?
reagrds
Joerg (ifixit@xyz.logopainter.de)
Joerg Peters - Antwort
I have the same problem ? Where I can obtain a new motherboard ?
Stefano Antoniutti
anto5657@alice.it
Stefano Antoniutti - Antwort
Were you able to buy the motherboard?
Rodrigo -
Rodrigo
rodrigo@r7criacoes.com.br
Rodrigo - Antwort
i also facing same issue, where can i get new motherboard ?
riyupc123@gmail.com
Riyu PC - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 15
Insgesamt: 1,776
