Einleitung
Use this guide to replace your iHome iP1's damaged or faulty speaker(s). Note that starting at Step 7, this guide only shows you how to replace the left speaker. To replace the right speaker, simply follow Steps 7-9 as if they are mirrored.
Was du brauchst
Orient the iHome upside down with the speakers facing away from you.
Remove the four 9.5 mm Phillips #2 screws located on each of the four corners of the iHome's back cover.
Disconnect the white/black wires from the edges of the motherboard by pulling them away from their connection.
Carefully remove the glue attaching the wires to the housing using a metal spudger kit.
Rotate the iHome so that the speakers are facing you.
Remove the speaker covers by pulling them off of the faceplate.
Remove the speaker from the housing by gripping the rubber ring near the edge of the speaker and pulling it away from the faceplate.
Remove the speaker from the iHome by feeding the black/white wires through the hole on the opposite side of the housing.
2 weitere Personen haben diese Anleitung absolviert.
