Zum Hauptinhalt wechseln
iHome iP21 Display LED Replacement
Was du brauchst
  1. iHome iP21 Display LED Replacement, Base: Schritt 1, Bild 1 von 3 iHome iP21 Display LED Replacement, Base: Schritt 1, Bild 2 von 3 iHome iP21 Display LED Replacement, Base: Schritt 1, Bild 3 von 3
    • Pry the four rubber feet from the bottom of the iP21 to expose four 11mm screws.
    • Unscrew the four 11mm screws from the base.
    • Pry the base loose using the spudger.
    • Remove the base by hand.
  2. iHome iP21 Display LED Replacement, Housing: Schritt 2, Bild 1 von 2 iHome iP21 Display LED Replacement, Housing: Schritt 2, Bild 2 von 2
    • Remove the two black 6mm screws connecting the main circuit board to the housing top.
    • Gently pull front housing from the back housing.
  3. iHome iP21 Display LED Replacement, Remove Speaker Assembly: Schritt 3, Bild 1 von 1
    • Remove two 9mm screws holding speaker assembly in iP21, using iFixit Phillips #2 bit
  4. iHome iP21 Display LED Replacement, Remove speaker from speaker assembly: Schritt 4, Bild 1 von 2 iHome iP21 Display LED Replacement, Remove speaker from speaker assembly: Schritt 4, Bild 2 von 2
    • Lift speaker assembly
    • Remove four 7mm screws to detach speaker from speaker assembly
  5. iHome iP21 Display LED Replacement, Display circuit board: Schritt 5, Bild 1 von 3 iHome iP21 Display LED Replacement, Display circuit board: Schritt 5, Bild 2 von 3 iHome iP21 Display LED Replacement, Display circuit board: Schritt 5, Bild 3 von 3
    • Remove six 6mm screws from display circuit board.
    • Press black holding clips down and outward to release display circuit board.
    • Lift display circuit board to detach it from the housing.
  6. iHome iP21 Display LED Replacement, Cables: Schritt 6, Bild 1 von 2 iHome iP21 Display LED Replacement, Cables: Schritt 6, Bild 2 von 2
    • Desolder the solder joints connecting the grounding cable to the display circuit board.
    • Remove glue from the ribbon cables with your fingers. Grasp and pull the glue to remove it from the circuit board.
    • Desolder the solder joints connecting the three ribbon cables to the back of the display circuit board.
    • Desolder the solder joints connecting the two grounding cables to the back of the display circuit board.
    • Desolder the solder joints connecting the two grounding cables to the back of the main housing.
Abschluss
Brandy
601 Reputation
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 313
