Zum Hauptinhalt wechseln
iHome iP21 Docking Station Pin Replacement
Was du brauchst
  1. iHome iP21 Docking Station Pin Replacement, Base: Schritt 1, Bild 1 von 3 iHome iP21 Docking Station Pin Replacement, Base: Schritt 1, Bild 2 von 3 iHome iP21 Docking Station Pin Replacement, Base: Schritt 1, Bild 3 von 3
    • Pry the four rubber feet from the bottom of the iP21 to expose four 11mm screws.
    • Unscrew the four 11mm screws from the base.
    • Pry the base loose using the spudger.
    • Remove the base by hand.
  2. iHome iP21 Docking Station Pin Replacement, Housing: Schritt 2, Bild 1 von 2 iHome iP21 Docking Station Pin Replacement, Housing: Schritt 2, Bild 2 von 2
    • Remove the two black 6mm screws connecting the main circuit board to the housing top.
    • Gently pull front housing from the back housing.
  3. iHome iP21 Docking Station Pin Replacement, 30-pin docking mount: Schritt 3, Bild 1 von 1
    • Locate the 30-pin docking mount on the iP21. The 30-pin docking mount is visible on top of the iP21.
  4. iHome iP21 Docking Station Pin Replacement, Protective cover: Schritt 4, Bild 1 von 2 iHome iP21 Docking Station Pin Replacement, Protective cover: Schritt 4, Bild 2 von 2
    • Remove the four 4mm screws from the protective cover using the iFixit Phillips #1 bit
  5. iHome iP21 Docking Station Pin Replacement, Ribbon cables: Schritt 5, Bild 1 von 3 iHome iP21 Docking Station Pin Replacement, Ribbon cables: Schritt 5, Bild 2 von 3 iHome iP21 Docking Station Pin Replacement, Ribbon cables: Schritt 5, Bild 3 von 3
    • Grasp plastic cable connector ends
    • Remove the mini circuit board with 30-pin mounting dock from the two black plastic pegs.
    • Rock gently back and forth and pull to detach mini circuit board with 30-pin mounting dock attached.
Abschluss
Brandy
601 Reputation
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 713
