Zum Hauptinhalt wechseln
iHome iP21 Motherboard Replacement
Was du brauchst
  1. iHome iP21 Motherboard Replacement, Base: Schritt 1, Bild 1 von 3 iHome iP21 Motherboard Replacement, Base: Schritt 1, Bild 2 von 3 iHome iP21 Motherboard Replacement, Base: Schritt 1, Bild 3 von 3
    • Pry the four rubber feet from the bottom of the iP21 to expose four 11mm screws.
    • Unscrew the four 11mm screws from the base.
    • Pry the base loose using the spudger.
    • Remove the base by hand.
  2. iHome iP21 Motherboard Replacement, Housing: Schritt 2, Bild 1 von 2 iHome iP21 Motherboard Replacement, Housing: Schritt 2, Bild 2 von 2
    • Remove the two black 6mm screws connecting the main circuit board to the housing top.
    • Gently pull front housing from the back housing.
  3. iHome iP21 Motherboard Replacement, Circuit board: Schritt 3, Bild 1 von 1
    • Follow the prerequisite guide to remove the main housing.
  4. iHome iP21 Motherboard Replacement, Circuit board mount: Schritt 4, Bild 1 von 1
    • Remove the two 7mm screws from the circuit board
  5. iHome iP21 Motherboard Replacement, Mounting Bracket: Schritt 5, Bild 1 von 1
    • Remove the three 6mm screws to detach the circuit board from metal mounting bracket.
  6. iHome iP21 Motherboard Replacement, Cables: Schritt 6, Bild 1 von 3 iHome iP21 Motherboard Replacement, Cables: Schritt 6, Bild 2 von 3 iHome iP21 Motherboard Replacement, Cables: Schritt 6, Bild 3 von 3
    • Peel the glue from each of the three ribbon cable connections.
    • Remove the solder joints from the back of each ribbon cable.
    • Remove the ground wires by removing the solder joints on the back of the housing.
  7. iHome iP21 Motherboard Replacement, Detach cables from circuit board: Schritt 7, Bild 1 von 3 iHome iP21 Motherboard Replacement, Detach cables from circuit board: Schritt 7, Bild 2 von 3 iHome iP21 Motherboard Replacement, Detach cables from circuit board: Schritt 7, Bild 3 von 3
    • Remove glue from 3 ribbon cables from circuit board using fingers
    • Detach speaker cables from circuit board with soldering iron
    • Remove 3 ribbon cables with soldering iron
Abschluss
Brandy
601 Reputation
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 262
