Was du brauchst
Remove the two 8mm Phillips #0 screws from the iHome's iPod adapter.
Use the metal spudger to loosen the edges of the plastic cover.
Pull the adapter up and away from the housing, rotating it forward slightly as you lift it so the top faces you.
Pull firmly on the red and black cable connector to disconnect it.
Pinch the ribbon cable on both sides and pull it firmly to disconnect it.
Remove the four 7mm Phillips #00 screws attaching the black plastic cover to the bottom of the adapter assembly.
