Einleitung
This guide instructs you to replace the buttons in an iHome iPL8. The process includes using two sizes of screwdrivers.
Was du brauchst
Turn the device over to access the bottom panel.
Locate the 6mm Phillips #2 screw under the label "unscrew to open door."
Using a Phillips #2 screwdriver, unscrew the captive screw.
Keep turning until the screw and the door are loose.
Keeping your device upside-down, locate the four 6mm Phillips #2 screws near each corner.
Remove the four 6mm Phillips #2 screws.
Remove the four round pads from the bottom of the device.
Using a Phillips #2 screwdriver, remove the two remaining screws.
Put your hand on the silver bottom case and gently pull it outward.
Locate the green circuit board. This panel is clipped onto two black, circular-shaped columns at two corners.
Pull out the green circuit board on the two corners.
The green circuit board is attached to a black box at the bottom. Flip the panel and the black box together to open the device.
Remove the two 2.5 mm Phillips #1 screws securing the lightning dock assembly to the device.
Remove the two screws and the black cover.
Gently remove the lightning dock assembly.
Remove the two 2.5mm screws using a Phillips #1 screwdriver.
Remove the back cover.
Use your fingers to reposition the lightning connector.
Locate the light brown, rectangular button board. Remove the five 2.5 mm Phillips #1 screws, four along the perimeter and one in the center.
Remove the brown button board.
There is a foam sheet underneath the button board. Use your hand to take it off and put it aside.
There are two rows of buttons clipped on to the small, circular, black columns.
Gently unclip the two rows of buttons and remove them.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
