Einleitung
You will need to make sure the power on the device is off and unplugged to prevent injury. Use this guide to replace both of the speakers located in the device. You will need the iOpener or heat gun, the speaker will be glued down.
Was du brauchst
Make sure you remove all seven 3 mm screws before proceeding to the next step.
Be cautious when taking the top of the device off there may still be some adhesive stuck to device.
Be sure to unscrew (3 mm) the two plastic brackets on each speaker, use iOpener or heat gun they are glued onto speakers, please do not discard.
