Einleitung
You will be replacing the entire disk drive in your radio, the only special tool that is needed for this replacement are the iOpener or heat gun because of the adhesive.
Was du brauchst
Make sure you remove all seven 3 mm screws before proceeding to the next step.
Be cautious when taking the top of the device off there may still be some adhesive stuck to device.
Remove all four screws(13.5 mm in length) that are securing the device
Remove both of the connected cords on the motherboard.
Also remove the flat ribbon cable that is connected to the motherboard.
