Zum Hauptinhalt wechseln
iLive IKBC384S Motherboard Replacement
Was du brauchst
  1. iLive IKBC384S Motherboard Replacement, Top Cover: Schritt 1, Bild 1 von 2 iLive IKBC384S Motherboard Replacement, Top Cover: Schritt 1, Bild 2 von 2
    • Make sure you remove all seven 3 mm screws before proceeding to the next step.
  2. iLive IKBC384S Motherboard Replacement: Schritt 2, Bild 1 von 2 iLive IKBC384S Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Use iOpener or heat gun on all sides except the front.
  3. iLive IKBC384S Motherboard Replacement: Schritt 3, Bild 1 von 2 iLive IKBC384S Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Be cautious when taking the top of the device off there may still be some adhesive stuck to device.
    • The top of the device will be very difficult to remove because of the adhesive holding it together.
  4. iLive IKBC384S Motherboard Replacement, Motherboard: Schritt 4, Bild 1 von 1
    • After removing the top of the device, locate the screws on the motherboard. Gently unscrew all four of the 3.5mm screws on the motherboard.
  5. iLive IKBC384S Motherboard Replacement: Schritt 5, Bild 1 von 2 iLive IKBC384S Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Unplug the ribbon cable connected to the motherboard that stems from the disc drive.
    • Disconnect the two power connectors from the motherboard.
  6. iLive IKBC384S Motherboard Replacement: Schritt 6, Bild 1 von 1
    • You will need to desolder the antenna.
    • Be sure to desolder the piece connected to the motherboard not the wire.
  7. iLive IKBC384S Motherboard Replacement: Schritt 7, Bild 1 von 1
    • You will need to remove the speakers and power connector.
    • Once you have removed all of these from the motherboard, the motherboard can be removed
Abschluss
Tracy Walts
201 Reputation
2 Anleitungen geschrieben
Texas Tech, Team S46-G6, Bennett Spring 2017 Mitglied von Texas Tech, Team S46-G6, Bennett Spring 2017
TTU-BENNETT-S17S46G6
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 12
Insgesamt: 277
