Einleitung
You are going to replace the motherboard simply by unscrewing a few screws and then removing the motherboard from the device.
Was du brauchst
Make sure you remove all seven 3 mm screws before proceeding to the next step.
Be cautious when taking the top of the device off there may still be some adhesive stuck to device.
After removing the top of the device, locate the screws on the motherboard. Gently unscrew all four of the 3.5mm screws on the motherboard.
Unplug the ribbon cable connected to the motherboard that stems from the disc drive.
Disconnect the two power connectors from the motherboard.
You will need to desolder the antenna.
Be sure to desolder the piece connected to the motherboard not the wire.
