Zum Hauptinhalt wechseln
iMac G3 Model M4984 Optical Drive Replacement
Was du brauchst
  1. iMac G3 Model M4984 Optical Drive Replacement, Logic Board: Schritt 1, Bild 1 von 1
    • The iMac G3. This was a great computer for the time, and had plenty of features.
  2. iMac G3 Model M4984 Optical Drive Replacement: Schritt 2, Bild 1 von 1
    • Start by flipping the iMac upside-down. It may help to lay it on a towel, so you don't damage the screen, or scratch the face.
  3. iMac G3 Model M4984 Optical Drive Replacement: Schritt 3, Bild 1 von 3 iMac G3 Model M4984 Optical Drive Replacement: Schritt 3, Bild 2 von 3 iMac G3 Model M4984 Optical Drive Replacement: Schritt 3, Bild 3 von 3
    • Remove this Phillips screw.
    • Using a flathead screwdriver, work your way around the bottom cover, until it comes off.
    • Then, lift the bottom cover up and out, and set it aside.
  4. iMac G3 Model M4984 Optical Drive Replacement: Schritt 4, Bild 1 von 3 iMac G3 Model M4984 Optical Drive Replacement: Schritt 4, Bild 2 von 3 iMac G3 Model M4984 Optical Drive Replacement: Schritt 4, Bild 3 von 3
    • Now, remove the DB-15 Video connector from the logic board.
    • It may be helpful to use a Phillips screwdriver to remove the thumbscrews.
  5. iMac G3 Model M4984 Optical Drive Replacement: Schritt 5, Bild 1 von 3 iMac G3 Model M4984 Optical Drive Replacement: Schritt 5, Bild 2 von 3 iMac G3 Model M4984 Optical Drive Replacement: Schritt 5, Bild 3 von 3
    • Remove the power cable from the logic board assembly.
  6. iMac G3 Model M4984 Optical Drive Replacement: Schritt 6, Bild 1 von 2 iMac G3 Model M4984 Optical Drive Replacement: Schritt 6, Bild 2 von 2
    • Remove the front panel connector. (You may also need to remove an additional screw that connects the front panel connector to the logic board assembly).
  7. iMac G3 Model M4984 Optical Drive Replacement: Schritt 7, Bild 1 von 3 iMac G3 Model M4984 Optical Drive Replacement: Schritt 7, Bild 2 von 3 iMac G3 Model M4984 Optical Drive Replacement: Schritt 7, Bild 3 von 3
    • Now, remove these Phillips screws.
    • Now, grab the logic board assembly by the piece of plastic, and lift it out.
  8. iMac G3 Model M4984 Optical Drive Replacement: Schritt 8, Bild 1 von 1
    • The logic board assembly. This is the heart of the computer, it contains the motherboard, CPU, RAM, V-RAM, PRAM battery, the hard drive, and the optical drive.
  9. iMac G3 Model M4984 Optical Drive Replacement, Optical Drive: Schritt 9, Bild 1 von 1
    • Now to remove the optical drive!
  10. iMac G3 Model M4984 Optical Drive Replacement: Schritt 10, Bild 1 von 1
    • The optical drive is located near the front of the assembly.
  11. iMac G3 Model M4984 Optical Drive Replacement: Schritt 11, Bild 1 von 3 iMac G3 Model M4984 Optical Drive Replacement: Schritt 11, Bild 2 von 3 iMac G3 Model M4984 Optical Drive Replacement: Schritt 11, Bild 3 von 3
    • To remove the drive, push it in, lift up, and then pull forward.
    • As you pull the drive forward, disconnect the ribbon cable and set it aside.
  12. iMac G3 Model M4984 Optical Drive Replacement: Schritt 12, Bild 1 von 3 iMac G3 Model M4984 Optical Drive Replacement: Schritt 12, Bild 2 von 3 iMac G3 Model M4984 Optical Drive Replacement: Schritt 12, Bild 3 von 3
    • Remove the two phillips #00 screws.
    • Then remove the board. This will reveal that it is a standard PATA drive.
    • Congrats, the drive is free! You can use any PATA-tray loading drive in the iMac G3 which means you can install a CDRW to burn CDs in OS9 or X(if using OSX,install that DVD writer) but, of course only original drives will match the great look of the iMac).
Abschluss
15 weitere Personen haben diese Anleitung absolviert.
Chris Green
38.312 Reputation
49 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
333 Mitglieder
1.478 Anleitungen geschrieben
1 Kommentar zur Anleitung
Awesome writeup! Thank you!! Though I've got my doubts I'm going to be able to find a replacement drive in good condition :/
jaxxthecollector - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 31
Letzte 30 Tage: 168
Insgesamt: 19,388
