Einleitung
This step will help you connect to wireless internet and get you back to surfing the internet faster than before. You can add a AirPort to your computer even if it did not originally come with one.
Werkzeuge
Ersatzteile
Kein Ersatzteil erforderlich.
Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
Use a spudger to lift and remove the AirPort's antenna connector.
10 weitere Nutzer haben diese Anleitung absolviert.
2 Kommentare
Make sure to insert the AirPort Card with the label facing down, away from you.
Does the antennae cable not plug into the card - Your illustration shows a large cable simply taped on top of the card and, as far as I can see, a smaller thinner cable that appears to be going to the card. I have the bigger cable in my iMac but it dues not appear to fit into the card - Do Inhave the wrong card or something?
