Einleitung
Upgrade your RAM DIMM Module for more memory.
Was du brauchst
Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
Release the tabs on each side of the module by simultaneously pushing each tab away from the RAM.
Remove the RAM module from the iMac.
10 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Please correct the title, this is a 144 pin SODIMM, it is not a DIMM
The 168 pin DIMM is used in the internal socket.
Thanks For catching this Typo! :-)
